No, but the application is everything.
In PCMO/HDEO, good and bad is pertinent to whether it's the RIGHT/CORRECT oil for the engine at hand. SM oils in a 600 HP 454 70 Vette with a lot of lift and high compression, no cat would be a BAD oil. 15W40 HDEO with lots of zinc would be a GOOD/CORRECT oil for the 454, but not so hot for my roller-skate DOHC 106HP Hyundai which specs SM-graded oil with little (by comparison) zinc. It isn't that any oil, syn or dino, is good or bad, it's the application and whether THAT oil is correct for THAT application. No particular oil is universally ideal for every engine.
Same extends to the user. Why run 6.00/quart syn for a 3K OCI when a cheaper dino, for 3K, will do the same job for you? It's all about the application, not so much the oil.
