JTK
$100 Site Donor 2025
I can't tell what engine this snowblower has, but the rubber and plastic quality on Chonda engines is horrible. Sorry if I missed it in this thread, but the primer bulb hose is probably dried out, cracked and split open. Very common on these. I keep an assortment of sizes of amazon purchased gas line for this purpose. The primer bulbs themselves will fail as will the fuel line, fuel shut-off valve, etc. I suggest not using the fuel shut off valve if it's made of plastic. Keep in "ON" and leave it on unless you have to use it. Plastic fuel tank caps on Chondas will also eventually fail. The engines themselves are great. Just all the soft bits suck and have since day one with these Chinese import engines.
In terms of the carburetors on them. I just mail order and replace them, being sure to keep the OEM in the replacement's box in case I want to dig into it.
