Hey everyone, I’m having a really tough issue trying to fix with my 10 year old 32 cc 4 cycle craftsman leaf blower. Long story short it dies at wide-open throttle. It has 6 months on use when new it started died at wot then it sat for 10 years until I decided to fix the initial issue recently.
I clean the oem carb - 7 times… used to two cans of carburetor cleaner and ran wires through the Jets, Rebuilt it with new gaskets and everything. Still dies at wide-open throttle. Replaced it with Amazon special ran worse!! Put oem factory one back on… Replaced both fuel lines and in-line fuel filter in the tank, OEM genuine spark plug gap to correct gap… adjusted both valves to factory spec. What is going on here!
it’s one pull start and idle, and 80% throttle it’s fine, but at wot, it sputters and dies.
should I replace the carburetor with an OEM genuine one? its 50 bucks.. but It’s so simple I cannot imagine it being shot, what would you do in this situation?
thanks for all feedback!
