I had a leak in my motor guard bypass and decide to remove some of my many fittings. I was tightening a barb fitting on it when I felt it crack. I got out a flash light and sure enough it is cracked when the fitting goes into the housing.
I removed it but what do you think I should do about it? I’m thinking about buying a new motor guard and taking the parts of my old one, the center tube and restrictor and making a new bypass oil filter.
I don’t trust the crack one. I’m thinking of using it on my air compressor to filter out moisture from the air line. I’m not sure if it will hold pressure but I don’t trust it filtering motor oil.
