99 Chrysler Town & Country 3.8L. Engine cuts out and drops rpm several times a minute. 196,000 miles.
A mechanic told the old owner it needed a new flywheel.
It throws a code that it is loosing signal from either the camshaft sensor or the crankshaft sensor.
Could that be because the bad flywheel is throwing off the crankshaft position indicator?
I put a new crankshaft position indicator and it runs the same.
About how much to have a new flywheel installed if needed?
Thanks for any help!
