Well so far the KLIM is a heaping pile of poop. The 3M adhesive to stick it to the bottom of the laptop isn't strong enough to keep the device from falling off the laptop and the suction cups are so weak they won't stick to my laptop either.
You're right but it's doing both. When FPS is lower, it reduces work for the CPU too.By limiting the max FPS you’re limiting the GPU usage and in a roundabout way, the power it uses. Which proves my point that it’s the GPU that dumps the heat to the CPU.
If I had to guess, in this pic it’s on the right, so left when in use. Also assuming this is the right mobo. The other ones have black heat pipes, but same thing.The laptop is a little over a year old. I used to use MSI afterburner and Riva Tuner with Oblivion Remastered but Riva interacts with UE5 and makes stuttering worse.
I just bought the little doohickie Marcozi posted a link to. My main question right now is, is the CPU on the right or left side of the laptop?
Since it's a laptop don't forget about battery thermal throttling. Total power draw will be reduced by reducing load. Have you tried with just the power adapter and no battery?
I have encountered situations where running A/C power with the battery installed during high load makes even higher battery temps than pure battery. Depends on the battery management.
Silicon heats up fast and cools fast. Should notice your problems much sooner than you describe if it was the chipset itself.
It doesn’t help they’re running BOTH Gamebryo and UE5 for Oblivion Remastered. They’re using Gamebryo for the physical gameplay and UE5 for the visuals. Gamebryo was last updated in 2012!Turns out the problem lies with either the game or UE5. 95c is my lowest temp with the KLIM.
Other games run much cooler. Bethesda needs to hurry up and patch this game.
It's on a stand so it has room to suck in more air. If you read back in the thread I purchased a KLIM Tempest and it works well expect for on Oblivion Remastered. The game itself causes very high cpu temps.But will it run Crysis?
Does your stand have fans in it to blow air upwards towards the laptop? Those will help more as you can force more air into the various vents and both heatsinks.
Thank you kind sir.Try something like this: https://www.amazon.com/dp/B08P8JCBB7?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
You're welcome.Thank you kind sir.
I fixed all the issues by downloading throttle stop. Powermode is set to balanced and I have disabled turbo mode for the CPU.
I'm now gaming at 40-60c with no noticeable decrease in FPS.
