Just bled my brakes, big thumbs up for the pb blaster, worked like a charm to loosen up those bleeders! Anyway, I was wondering where I can pick up some of those rubber nipples for the bleeders? mine pretty much crumbled off when I removed them. Also, how often do you guys change power steering fluid? I have never done it and was wondering how its done. Any do's or donts to know before I break something?
one more thing, I sprayed the bleeders with a bunch of contact brake cleaner when I was finished, hoping to help keep the bleeders from welding themselves on. Didnt someone on here say that brake fluid is one of the reasons the bleeders rust on so bad? Is contact cleaner bad to get on any other components? will it harm the seals in the calipers? I washed it off really well just in case but was wondering how hard it is on plastics/rubber
