couple of oil recommendations please
TN
Hey everybody, new guy here from TN! I have a 2000 camaro that I bought brand new. It now has 105,000 miles on it. It has the 3.8v6 in it. The manual calls for 10w30. I have always used Castrol Syntec 10w30 in it. It has never had a drop of anything else except what it came with from the factory. With the mileage getting up there on it, should I switch oil or is that a good oil to use?
Also, about 3 months ago, I bought a 2002 silverado with a 4.8v8. It has 73,000 miles on it. The manual calls for 5w30. About a month ago, I changed the oil and used Amsoil XL 5w30 and the amsoil oil filter. I was a little nervous about using it since it didn't have the api starburst on the bottle. Also, since switching I can hear a knocking noise when the truck is cold and the noise clears up when the engine warms up a little.
I don't drive hard and I always take good care and keep up on all the maintenance. Are the oils Im using in these vehicles the right choice? Also, are they true synthetics? Btw, I don't drive long distances in these vehicles and the camaro is usually parked during the winter.
Thank you for any advice,
Andy
Welcome to BITOG.
As they say, if it ain't broke...
Heh... that's a loaded question on these forums. It really depends on your definition of "true synthetic". If by this you mean "group IV/V" base, then the answer is 'no'. However, this does not mean they're bad oils at all.
No real problem with what you're doing, and either would be fine with moving to 5/10w-30 for both.
IMO however, Shell Rotella T Synthetic 5w-40 is a viable option for both. It's a relatively thin 40-weight but the slight increase in thickness may help with noise, plus its just a great HDEO oil.
I have a 3.8 L 2000 model as well, stay with what you are using if you have not problems. A lot to be said for "if it ain't broke don't fix it" saying
Sounds like you already have a recipe for success with the camaro, I wouldn't change anything. As for the 4.8L, they are famous for cold-start piston slap. While annoying, it won't damage anything. If the noise bothers you, some people report that 10w30 or 5w40 helps "dampen" the noise.
Ok thanks for all the replies! I will stick with castrol syntec on the camaro. I would like to get a used oil analysis on my next change cause about 2 oil changes ago, I had to replace the upper and lower intake gaskets. I want to make sure there is no coolant getting in the oil. I don't think there is though.
As far as using the amsoil 100% synthetic high performance oil 5w30 on the truck, is that a good choice even though it is not api certified? It is not the xl oil like I thought.
