I love how relatively evenly spaced our gears are. My old Durango had the 545RFE and 3.45 gears... 1st gear was ~50mph and 2nd gear would take you to 90!It's that **** double overdrive! LOL! In 1:1 (6th) it tops out at 138:
Michelin sipes look wider as well. I suppose tread compound plays a factor in the overall wet weather performance though.In reality, he just didn't cancel the Michelin order, figured they'd be good to have in stock either way.
Looking at the two tires side-by-side, while the tread pattern is very similar the Michelin clearly has massively more siping.
definitely look how many sipes summer tires have(not many) yet they have really good wet traction.Michelin sipes look wider as well. I suppose tread compound plays a factor in the overall wet weather performance though.
I'd go with the Conti's. A little more void and slightly deeper tread. They might be better in heavy rain and snow and last longer than the Michelins.
I fell off the Michelin band wagon after I bought a set of LTX ATs in 275/65/20.
Some of the LTX-ATs had 3 steel belts and no nylon cap plies to hold the tire together at high speeds. The 275/65/20 was one of them, good to 60 mph. The stock size in 2500s and 3500s was 265/70/18 (2019 and older). Those LTX-ATs had 2 ply sidewalls, 2 steel plies and 2 nylon cap plies, and did not exibit high speed issues that made the tires seem out of balance. One tire tech at Costco spent 2 hours trying to balance my 20s while I shopped. The continous high speed shaking on trips across the prairies wore them out in 35,000 miles (60k kms).Yes, the LTX A/T was a blem on what has otherwise been a world-class product line.
Dunno why, but the sidewall design is a bit less aestetically pleasing to me than other tires.
As @4WD can attest to, my sidewalls are always filthy, so that won't be an issueDunno why, but the sidewall design is a bit less aestetically pleasing to me than other tires.
Yet to find a tire that glues like PSS to the road in wet.Yup, the PSS I owned had zero sipes and were like epoxy in the wet.
I think the conti sportcontacts are better, atleast by autocross results, and probably most of the 200tw autocross tires are better too, but not as streetable as the sportcontacts. I do find it interesting the PSS is considered one of the best gripping street tires but they aren't competitive for serious autocrossers?Yet to find a tire that glues like PSS to the road in wet.
The TireRack results seem to favour the Michelin?I think the conti sportcontacts are better, atleast by autocross results, and probably most of the 200tw autocross tires are better too, but not as streetable as the sportcontacts. I do find it interesting the PSS is considered one of the best gripping street tires but they aren't competitive for serious autocrossers?
