I am about 600 miles into Auto RX treatment in a Hyundai Accent with 136,000 miles. The car had lifter chatter when it was in a pull before the treatment.Now there is no rattle in the lifters at all.Could it be the Auto RX?
Quote:
You sound like you're describing spark knock. Auto-Rx could effect that in a second or third order kinda way. It could clean up the pistons (the crankcase side) and allow the oil to cool them more effectively. It could allow rings to seal better, reducing blow-by that, if too high in oil vapor content, can cause some knocking.
If nothing else was done to the engine ..then it points to Auto-Rx as the contributing element to the elimination of the condition![]()
Now for true HLA ticks ...Auto-Rx was the ONLY product to cure my old 3.0 Mitsubishi. MMO, kerosene in a can motor flushes, thin oil ..thick oil ...Seafoam ....motor medic ..you name it ..nada ..zip. I would get the strangest cyclical lifter noise that would continue until the oil got warm ..but it wasn't a static lifter tap. It would cycle from one ..to all ..recede ..to one ..progress to all ..and so on until the oil was fluid enough. The rinse phase produced radically different and new ticks ..but they all receded in time. I was then left with very slight HLA noise at idle with 5w-20 oil. This is with 170+ on the HLAs. Not noisy per se~ ..nothing that any owner of a new engine may hear if idle visc is a tad too low. Keep in mind that the 3.0 was never spec'd for 20 weight oil.
This forever settled any debate in my mind about Auto-Rx. It may not cure the common cold ..but in my case, it cracked a decade old nut that defied remedy for me.A side benefit (greatly appreciated) was the near elimination of the "fogger syndrome" that plagues the older Mitsubishi engine. Self esteem advanced a notch or two when driving where frequent stops and idling were involved.![]()
