Originally Posted by Cressida
Originally Posted by Donald
They legs of 220V can be called a few things, but never phases. A home is always single phase. Only big factories are 3 phase.
I guess different parts of the country do things differently. My 1900 sq. ft. home built in the 1950's has always had 3 phase service. My main panel is the typical single phase but there is
a separate panel in the attached garage that has 3 phase going into it. I think it's fused for 60 amps. The only thing that panel has ever serviced is the outside A/C unit which has a 3 phase
compressor. I replaced the HVAC system in 2014 and could have gone with a single phase A/C at that time but since I have 3 phase service I stayed with it - why not ?
That's not overly common but isn't unheard of for houses in the 40-60s for the reason you mentioned- the AC compressor. Once the single phase motors started getting better and more efficient that more or less went away. Even around here large houses with 600-800amp services are always single phase, but that might be utility (Peco/Exelon) driven as well.
