Correct way to describe gearing (low or high)
Elkins45
Site Donor 2026
Northern KY
I was discussing the difference between the gearing in my old manual xB vs the automatic. At 70 mph the auto runs at 2700 rpm while in 5th gear the manual was at 3000. Since the manual runs at higher rpm is it correct to say that it's "geared lower" than the automatic because the ratio between engine revs and speed is lower? Or do I have that backwards?
I agree with you.
I would call the higher rpm a lower gear, I would also call that a higher ratio. I.E. 4:10 to 1 is a higher ratio, but a lower gear. Verses 2.76:1 which is a lower ratio but i higher gear.
Think of it in terms of bicycles. Low gear = low speed. Machines have the advantage of caring less about RPM than human legs (proper cadence is a separate issue)
Or just look at any t-case lever: 4lo
The phrase "shift into high gear" means "andale, rapido!!"
I'd be willing to bet the axles are geared the same, and the difference in engine speed is due to the transmission gearing.
But to answer original post, geared lower or shorter gears is how I've always heard it.
Lower/higher generally used for street vehicles, and shorter/taller for offroad vehicles. Not my nomenclature, just the way I've heard the terms used.
