Any plumbers out there? My to-do list this past holiday weekend consisted of replacing the tank internals of a couple of our toilets this weekend. Easy job and not too expensive. But here's my question: The inside of my tank says the water level should be 5/8" below the top of the overflow pipe. The instructions that came with the new flow valves said 1/2" to 1". In an effort to conserve and reduce water usage, I adjusted the floats such that the water level is 2 1/8" below the top of the overflow pipe. Am I breaking some code/regulation or otherwise creating an issue in doing this?
