As long as the blades aren't up side down, just bolt them on, it doesn't matter.. There will always be some slippage of the mower belt around each blade's pulley and each blades orientation will change as well. You are making a science project over this.I'm replacing the blades on my 26hp 50" inch Craftsman PYT 9000 lawn tractor. It has 3 blades. Should they be installed so they all turn in the same direction at the same time? I'm wondering about balance.
