First of all, I enjoy these brain teaser questions. It really give my brain some exercise. The biggest difficulty with these questions is that they need to be researched on-site or in person.
I am assuming the 4x4 posts are continuous from the footing up the the rafter. This is going off your ten foot post description. The posts in the drawing appear to be plumb up to a point where the load of the roof has splayed the tops outwards and this is the area you want to stabilize. Correct me if I’m off on any of this.
I think a wire rope (cable) is better suited here using a turnbuckle to apply tension. The question is how to attach the cable to the wood posts. Drilling a hole straight through the post and then installing a eye bolt with a oversized washer on the opposite side could work.
From the drawing it looks like there is not enough collar beam support at the junction where the post starts to splay. Do you have plans to build extra support once you stabilize the structure?
I sure appreciate your help!
Sorry if I wasn’t clear. I’m putting 4x4 up on the outside, horizontal, at the top plate of the building to help pull the outward bowed studs in a bit while also helping the ridge to raise slightly.
The roof has purlins with cedar shakes, with asphalt roof on top of that. So lots of weight on an undersupported structure. So the plan is to pull in, remove dead weight, and add the bracing that needs to be there. Currently there are only rafter ties 1/3 of the way up, every other rafter, and no collar ties.
The purpose of all of this is to pull the stud tops inward by using wood across multiple studs to gently pull them in. On a 40ft building I’m going to pull in about 32ft worth across the center of the building.
So the 3/4” eye bolts are 4’ from the ends of a 16ft 4x4. Pulled up from the ground to just below the top
Plate. Holes in the sheathing allow the eye bolts to come through into the building, the the chain tensions inside.
So these are horizontal 4x4; parallel to the ground, across many studs at the top of the building.
I estimate the roof marerials to be around 13000 lb. Of course I’m not going to fix everything by exerting that much lateral pressure on the building, but it seems that in aggregate I need something in excess of that in terms of rated tensioning capacity.
