Hi everyone, recently noticed my auto trans seems to be acting up, taking long before it shifts gears. Usually it changes gears at just above 2000rpm, but since the past month or so its delayed and seems to be shifting oddly. I change the transmission fluid regularly, I changed it for the 2nd time in Summer just past. I also had the spark plugs changed, along with suspension parts, new intake gasket and new auxiliary belt. Does anyone have a Corolla from these years? If so, I am looking for advice, if you have used any kind of additive to the T-IV fluid like lubeguard with positive results or if there is a better fluid I could use safely without making things worse? Also.. wondering if it would be worth changing out the transmission filter, I know the dealer only does drain and fills, as I do myself. I am at 125k miles currently and have done 2 drain and fills. I don't know if this is related but the car also feels weaker than usual.. but no Check engine lights/codes. Anyone have recommendations of easy/cheap things I can test or check on? Appreciate your advice! Thx
