Hi all:
1991 Plymouth Acclaim 2.5 120,500 miles
I have had this car for about 2 months now, and still have a lot of work to do...
The previous owner of the car said that there was a slight coolant loss after time. I have not noticed any change in level after 2 months of using it hard. I have noticed, however, that the radiator is quite dirty, and the coolant is kinda dirty too. The oil was not murky, and there are no bubbles coming from the coolant reservoir. Does this sound like the normal loss that all fluids have?
Since everything is dirty, and I have just gotten this car I was thinking about flushing the system. I went to Autozone, and got a new radiator cap, thermostat, thermostat gasket, flush hardware, and flush solution.
Does anyone have any suggestions about flushing the cooling system? Will this majorly harm anything? Mainly, I am worried about causing leaks by flushing the system. Should I try and use clean and clear instead? Would this clean my system of the crud as well as the flush? Which is preferrable?
Also, Autozone recommended that I use the 192 degree thermostat. Does this sound right? They said that the only difference was that the 192 degree thermostat would give me more heat from the heater in the winter. What are the pluses and minuses of warmer versus cooler thermostats?
Also, they only had an Autozone branded thermostat. Will this brand be alright? Is there a better brand that I should be looking for?
I appreciate all thoughts on this matter.
Thank you.
David
Thank you.
David
