Coolant level sensor hole plug?
For my daughter's 03 Buick Lesabre; I purchased an all aluminum aftermarket radiator. (eBay) It comes with a hole for a low coolant level sensor; there is not such a sensor on her car nor is there wiring for such. All I really need is to plug the hole so the radiator is actually useable. As best as I can physically measure, the hole is 12mm diameter and 15mm+ deep. Local parts stores have "low coolant level sensors" in stock and I'm sure that would work, I just hate to buy a sensor when I know the right size PLUG would work for much less than an actual sensor. Where to find such critter? Thanks in advance.
Thanks; but it's NOT a threaded hole, a low coolant level sensor simply pushes in the hole and is held and sealed by two O rings and a wire retainer. I have emailed the manufacturer and they responded and stated that they do not sell plugs for the hole nor coolant level sensors nor do they know where to obtain them.
I think all you can do is get an old one from the scrap yard to plug it up.
Thanks, I may end up doing this; but the part needs to seal and not leak....Really hate to use junkyard (scrap) part on a pressurized system. I would definitely replace the O rings.
I wonder if a rubber expansion plug would work. I didn't search exhaustively, but found this one in a diameter that would fit. I'm not sure about the depth, or how much to trust the lever mechanism vs. the screw-type. I have used the larger screw-type plug to replace freeze plugs on an engine. They worked well, but I did snug them up occasionally.
You could also buy a cheap sensor and install it. Electronics quality wouldn't be a concern, and hopefully a cheaper one wouldn't leak.
https://www.grainger.com/product/SHAW-PLUGS-7-16-in-Snap-Tite-Mech-Expansion-6VFR2
I sincerely appreciate your response, but this plug is rated for 25 ft of head pressure which works out to about 10.8 psi https://www.engineeringtoolbox.com/pump-head-pressure-d_663.html Not quite enough for normal (15 psi) radiator...But I give you E for effort. I'm grateful for responses.
I think we ran across the same issue. I bought a 3 row radiator by alloy works that was listed as being for the model years 00-05 but the coolant level sensor port is for the sensor from model years 96-99. I found a company that makes a plug that looks to fit the specs for the port but I couldn't find any place that stocked the part. Northern Radiators RW0008-27. The wild part to is if you wanted to buy the sensor to fill the port the cheapest one I could find was like 70 before tax.
