Coolant leak detector UV dye not safe to use with Deathcool
USA
This Autopro UV coolant dye says not to use with Dexcool :cautious:
Autozone:
Certified A/C Pro Engine Cooling Systems UV Dye is an engine coolant UV dye for leak detection. Includes one application of radiator/engine cooling system UV leak detection dye. Safe for use in all vehicle makes and models (except 1996 and newer GM models that use DEX-COOL coolant). Compatible with all types of anti-freeze except GM DEX-COOL coolant.
-Contains one application of radiator/engine cooling system UV leak detection dye
-Safe for use in all vehicle makes and models except 1996 and newer GM models that use DEX-COOL coolant
