Not necessarily true. If it goes back hotter(lower concentration anti-freeze)) it "may" not pick up as much heat as the higher antifreeze concentration concentration (which will enter engine at a lower temp. Why?- Because the heat picked up is directly proportional to the difference between the bulk temp of the coolant and the temperature of the hotter surfaces it contacts. The greater the temperature difference the greater the heat transferred. Heat capacity is only one part of the equation. But again only a flow model depicting the basic parameters can tell for sure.quote:
Originally posted by labman:
Clicked on the wrong buttton. What I meant to say was:
The water may still be going back
hotter, but it lost more heat, and will
be able to absorb more heat in the
engine.
You may be right in some engine/radiator configurations-you may not be.
