Yes, people blame prior Dexcool issues on the coolant, or the service interval, when it was the gasket type used or cooling system that didn't keep air out and the level full was to blame. Yet many other applications run the same Dexcool way over 5 years and never have any issues. This proves it isn't Dexcool or the service interval to blame.
Dexcool service interval is 5/150k miles which is conservative. But both time and milage counts. So if you have 5 years and say 40k miles or any milage under 150k miles the recommendation is to change it. Coversely if you have over 150k miles but less than 5 years the recommendation is to change it.
The assumptions are that you will do a complete change over, use decent water, and get at least 50% concentrate. Under those assumption Dexcool's service life truely is underrated and could go longer and still protect.
It's not a bad idea to stay in the 5y/150k mile change interval, but exceeding it isn't what was causing gumming on certain models.
HD application run coolant pretty much similar to Dexcool for 300k miles and then add an extender and go 600k miles. Diesels would be more demanding on coolant than gas passenger vehicles. Although they may see 600k miles in around 5 years.
