Originally Posted By: Bluestream
Why do you think you need to filter your coolant?
I dont "need" one, I was just concerned by the amount of grit and other crud I found while flushing the radiator recently.
I have a remote filter mount from another project & found that Wix has a 3/4" threaded coolant filter with no added chemicals (24430) and thought that time-wise, it may be easier/cheaper than the flushing process with this motor (2.7L V6 dodge).
Removing the thermostat is no easy task with this motor, so I drained, refilled/burped the system, and drove for a few days, repeating this process four times and still had grit (and G05). The whole process took about 45 minutes on average.
Originally Posted By: Kestas
How will the coolant filter cause corrosion? Corrosion only occurs when dissimilar metals are in contact with each other in the presence of an electrolyte. If the metal components are electrically separated, such as by rubber hoses, there should be no corrosion.
I also admit to not having a firm grasp on the phsyics involved, but I figured most remote mounts are cast aluminum directly in contact with a (I assume) steel-bodied filter and whatever else makes up the construction of said filter.
Thanks again for the input guys, I appreciate it!
