Do they make coolant filters for passenger cars like that do for OTR trucks? Or someway of adapting into a current coolant system to add the removable filter.
Quote:
Would this be something I could use?
https://dynamic.donaldson.com/webc/WebStore/search/item_detail.html?section=10159&item=1857
I took a quick look at the Donaldson link and they list SCA (Supplemental Coolant Additive) Coolant Filters .. These are intended for large Diesels and are designed to time release SCA’s .. You wouldn’t want to use one of these on a gasoline engine..
Quote:
Thanks for the information. What’s the reason not to use SCA's in a gasoline engine? ...
Quote:
I have not figured out exactly how to locate items on search feature, but am I correct in assuming that I can just break the heater hose (either side) and route to inlet and outlet of filter base?
Quote:
is the coolant bottle able to keep up with the flow?
