SilentType
Site Donor 2025
- Joined
- Jun 13, 2025
- Messages
- 216
I changed the coolant yesterday in the 07 Jetta with Zerex G40.
I removed the return line from the reservoir and connected it to a long piece of tubing to drain the old stuff, all the while adding distilled water to the reservoir. Went through 4 gallons of distilled and it was running clear by the third gallon.
Started pouring G40 concentrate and only got about 3 quarts when the car decided to stop sending water out the return line, so I decided to button it all up and call it a day. The system is full and was burped the best I could do.
The problem is this is a 10 quart capacity cooling system so I know there is ~30 percent coolant now which isn't enough. The old school tester shows good to -43F. That can't be accurate with a 30 percent mixture can it? Are there any other testers needed for modern coolants?
This is what I'm using.
