Coolant color has changed to light brown
2009 Rogue AWD. 52,000.
Looked in the coolant reservoir and noticed the color wasn't blue like it should be. I haven't looked at the coolant in at least 6-8 months so I have no idea how long it's been like this.
Here is what it looks like, it's a very light brown.
I just changed the oil today to see if there was any coolant in there and it was fine. I have checked my oil level often and it never lost any oil.
2 weeks ago I did use condenser cleaner on the condenser and then sprayed it with the hose to clean off. I don't know if that could cause this.
Checked all the hoses and nothing is leaking anywhere.
For the last week or so I have heard a quick squeal a handful of times when I turn right or am just going down the road.
Any help would be appreciated
I'd be draining or flushing that out ASAP.
I was thinking the same thing, but what if it just comes right back?
Temps are fine. Same as always.
I will dump it.
Could a failing water pump cause this?
Originally Posted By: 901Memphis
Send it in for coolant analysis, don't guess.
I totally agree, 25 bucks may reveal any serious problems.
It's unlikely to come back if you switch to a different brand and color.
I use the Prestone Dexcool (with distilled water) and that stuff remains pink forever.
Where can I send a sample? Blackstone doesn't do coolant analysis.
Is there anything I can buy to get test results right away?
Thanks!
Has anybody other than you worked on it in that time period? Coolant completely losing its tint is a bit baffling unless it has been swapped out for something else.
No I am the only one who has worked on it.
I know its very baffling!
The only thing I can think is that someone else suggested the water pump may be failing (perhaps rust got in that way) since for the past 2 weeks I've heard a squeal when driving or turning right every so often. Sometimes it doesn't happen for a day or two, then it happens twice in a day.
I'd call your local nissan dealer and ask to speak to one of the mechanics and then ask them if they've ever seen it before.
I wonder if heat is altering the color. +1 with checking with a Nissan dealer. Or send the coolant out for analysis and see what they say.
I am going to flush it out tomorrow morning, question, is there anything you recommend to add to help flush everything out?
I wouldn't use any additives. Just flush it with water until it runs clear.
