quote:
Originally posted by ZmOz:
I can't believe popular boating lakes aren't just a big oil slick...
Evaporates? Since when does oil evaporate?quote:
Studies show the oil discharged into lakes and rivers from 2-stroke engines rapidly spreads out to a thin film and actually evaporates pretty quickly.
As much as I wouldn't mind toppling the House of Saud ...I doubt that there's enough tillable earth available to produce enough agro-energy to replace the stuff that's already sitting there in the ground.quote:
oil Sheiks can crawl back in their Bedouin tents and suck on sand-covered tar balls for a change.
Ah, but that's the hook!quote:
Originally posted by Ray H:
What? Canola oil is not only one of the least saturated fats, it's also very low in transfatty acids. It's because of awareness of health concerns that Canola is in such widespread use these days.
Some of that ''factual data'' is confusing at best, and perhaps garbled. Since it wasn't widely available, or at least cheap, in the US back in the 70's, I never actually worked with Canola oil. Yes it is highly unsaturated, and has the same longer chain fatty acids as fish oil. Trans fatty acids are rare in natural oils. It is accepted, with good science backing it, that saturated fats are worse for us than natural unsaturated fats. Most harmful of all are the partially hydrogenated fats. Unsaturated hydrocarbons contain carbon to carbon double bonds, just like the AO's that are polymerized into synthetic oil. You can open them and add 2 hydrogens to each. This artificial process can leave trans double bonds if not complete. Only partially hydrogenated fats have the trans fatty acids. Canola oil is not necessarily partially hydrogenated. If you want to protect your health, pay more attention to the hydrogenation, than the type of oil.quote:
Originally posted by Lubricious:
Snip....
Here is some factual data
http://www.breathing.com/articles/canola-oil.htmsnip.... [/QB]
Were you referring to your motor, or your intestines?quote:
Originally posted by dustyjoe1:
If nothing else it should get rid of some of that 32 year old sludge
