Originally Posted by discountdon
Originally Posted by Mad_Hatter
It makes it a oil with stop leak, that's all. According to mfgs like Valvoline, Chevron and Mobil, High Mileage formulas not only contain seal conditioners but have a different detergent and dispersant PKG to combat excessive blow by that older engines can experience. Plus High Mileage formulas tend to, from what I've noticed, be on the thicker side and have more AW additives ppm as well as higher TBN's. Havoline High Mileage Synthetic Blend 5w30 for example has nearly 200ppm moly, ~11cSt 100c kv and a TBN of apprx 9. (those are apprx #'s, check the PDS for exact figures)..I know these figures off hand because it happens to be one of my favorite lubes. Quaker State High Mileage Synthetic Blend is also another great lube with similar numbers.
200ppm? that's more than Shell Rotella Gas Truck!
That's a "off the top of my head" figure, it's probably more around 180 or 190. I *think* Pennzoil High Mileage Synthetic Blend is well over 200ppm though..I thought it was somewhere around 250ppm, I'd have to check pqia to know for sure.
Edit: per pqia Havoline is 178 and QS is 193ppm and Pennzoil High Mileage is 258ppm.
Originally Posted by csandste
Did I read this, or just imagine it? I read (here?, maybe?) that all WPP? oils conventional (really blend), syn, regular or high mileage had nearly the same ad pack. If that's true, or even if it isn't: if a manufacturer took identical oils and put a bit of additional seal conditioner into some of them, those oils, by definition would be high mileage. I agree that most companies change the ad packs in hi mi oils as described above. I realize that I could look at Warren spec sheets and find out if my supposition is real or not, but it's the first day of winter and I'm tired.
It's possible in re WPP but you'd have to look for sure. There's no hard rule so to speak, so blenders are free to formulate away.. but as I stated, that (different addys) seems to be a trend across multiple mfgs. I believe Valvoline touts their High Mileage as having more dispersants to hold more soot until filtering, as to mitigate sludging... which can be a problem unique to older engines experiencing excessive blow by.
