quote:
Originally posted by Rick20:
Ross,
Likely your rear main seal leaks were due to debris lodging up under the lip of the seal. ARX cleaned it out. Petroleum oil tends to shrink and stiffen the seal. Now the seal has reconformed to the journal. Once this has soundly occured, you may run any oil. I would suggest may be running a conventional rinse phase as you have done. Plus one more 3000 mile run on conventional, before switching to a full synthetic or high mileage oil. You should be fine.
If the seal begins to weep again, you could probably just switch back to a conventional to slow or stop it again. This would indicate that the seal is probably close to calling it quits.
The "debris under the seal" theory is rampant, but I don't really know how sound it is. Speaking for myself, I've run nothing but high-quality synthetic oil (Mobil 1, Amsoil, or Redline) changed every 3,000 - 4,000 miles. I've run several Auto-Rx applications, and I have yet to see any evidence of any kind of sludge, debris, or dirt being "dislodged," even after three full Auto-Rx applications over the life of the vehicle. So yes, the seal may be worn, but I'm 99% certain there were no "false seals" that the Auto-Rx needed to contend with.
That aside, Frank has stated at least once on record that if you're trying to fix a leak, you
must stay with conventional after the Auto-Rx application. Off the record, Frank hints at a latent disdain for synthetic oil in general. I'm not certain that any of the reasons for this have much basis in scientific fact. Esters "competing for space" just doesn't cut it in my book ... either the Auto-Rx position is that synthetics cause/worsen/bring back seal leaks, or it isn't; and if that
is the position, someone needs to call the duck a duck: Frank believes synthetic oils are incompatible on some level with engine seals. Whether that's true or not is another discussion, but it seems a little disingenuous to me to say that the official position is that any oil can be run, when in fact Frank seems to believe that conventional oil is the only real way to go with seal leak applications.
