im confused about lube brake pad and brake caliper slide pin, they both use same lube ?
http://www.permatex.com/products/Automot...one_Formula.htm
http://www.permatex.com/products/Automot...s_Lubricant.htm
between those 2 which one better ? I want best of the best ^^
im thinking using that, I know that use on brake caliper slide pin, but can it use on brake pad where the piston push the brake pad to help brake quiet ? it caller shim right ?
