Conductive battery tester
Near the beach in Delaware
If you have one of these meters where you need to enter in the CCA, is the CCA only used to calculate the good/bad condition or is the test actually dependent on the CCA you enter
On a carbon pile battery tester you actually set it to 1/2 batter CCA so the load it puts on battery during the test is 1/2 CCA.
So my question is does what test the conductive battery tester does depend on CCA entered.
I do not see a CCA label on OEM Crosstrek battery. I can guess at 650. Maybe that's close enough.
Yes, I have the ANCEL BA101 battery tester which is popular here on BITOG. The State of Health % is calculated by the value that you enter for CCA (or CA). However, the actual CCA (or CA) test reading is also displayed on the results screen (see below).
Best investment, I learned the multi-meter method I have been using for years is for amateurs.
Toyota battery I purchased last month.
no way is a 2021 crosstrek battery 650, until recently they were way undersize.
Maybe 500cca. my 2015 forester was under 400cca.
IIRC the 22 forester wilderness was 500-550 range.
