Recommend battery tester for group 48 batteries
wwillson
Staff member
Colorado
The OEM batteries in our truck are just past 5 years old and likely are nearing end of life. Should I bother testing them or just replace? If you think I should test them, please recommend a good automotive battery tester.
I have both the "fancy" and the carbon pile testers, and I prefer the carbon.
They're all from the same factory, so here's a sketchy one from Aliexpress.
Obviously disconnect your interconnects so you get results for each individual battery, no matter what tester you use.
Carbon pile tester is the gold standard, but these work decently enough and highly rated by users and the Project Farm guy, if you want to search for his review on testers from a while back on YouTube. Ancel BA 101.
https://a.co/d/059uK4xq
Simple to use as well. I have purchased at least 8 of them and give them out as gifts to family and friends.
I have the Ancel, which was cheap (<$20 at the time), and does provide some data.
But keeping in mind its limits as a conductance tester, the conclusions it provides are no better than the simple household battery testers with the green/yellow/red scales to indicate the health of a cell based on its sole measurement of unloaded voltage.
A tester is nice to have, but if it were me I would go ahead and replace those batteries. After 5 years you have had great service.
I'm finding it difficult to find a tester for both 6v and 12v at a reasonable price.
I also have the Ancel tester, paid $<20 and it works quite well. Sure there not a carbon pile tester but there quite accurate for what they are especially with a little knowledge.
Likely the most telling piece of info they give that most ignore is the internal resistance. Generally your looking for <5 milliohm. A little more is OK but much past and the battery is likely too sulphated for long term continued use.
i get squirmy with old batteries. i’ve been the one asking for a jump in a parking lot before and it’s not the best feeling. Everstart platnium from walmart and be on your way
A reliable battery tester can be your best friend. I have had at least one for over 20 years. By testing a couple times a year, I have caught batteries that were getting weak, but not yet showing signs from simply performing a cold start. And on the flip side, I have got over 14 years out of one battery before it started showing some weakness on the tester. Currently I have two over 8 years and one over 7 years and all test fine still.
I tested the wife's battery which tested good. Two weeks later she was stranded with a dead battery. I'm replacing batteries every 3 years in the wife and daughter's cars now just to be safe. I don't mind being stranded but I don't like them stranded. I'm always doing something so much more enjoyable when I get that I'm stuck phone call.
I liked it better when we were leasing cars. Didn't have to fix, or worry, about much at all!
I bought this one because it will test 6v and 12v. We have many 6v batteries in large equipment that it would be nice to be able to test.
https://a.co/d/00HqCS68
I'm sure that one is fine, but I would have leaned toward the less expensive Ancel BA101 Plus that does 12vt and 6vt. I've never used either one, but there are a few more reviews of the Ancel and the rating is a bit higher...fwiw. The thermal printer could be useful on the Foxwell, but I just screen shot anything I want to save onto my phone from my Ancel, as it may be hard to find the printed receipt conveniently to refer back to.
As mentioned previously by AZ Jeff, it is not a bad idea to adjust the clamps after the first test and ensure they are securely attached, then test a second time to confirm the reading. These conductance testers can be finicky about having the clamps securely attached to the posts. I don't retest much anymore, as I have gotten good about making absolutely sure I have the clamps properly and consistenly attached the same way each time. But do it twice for the first few uses until you get confident in your clamping method.
I generally just watch my usb charger that has voltage readout to watch cranking voltage. Some can be off calibration a bit so you need to watch it.
Carbon pile tester on each from full charge with the tester cold to look at actual voltage drop is good.
5 years? I got 8 out of my 2011 F150 OE battery (SLA) and still have the OE in the 2018 (AGM) which is holding charge just fine and passes load testing with flying colors. Don't ask me how or why although I do "top off" the charge a couple times per year with my schumacher.
I just bought the wife a 26 rogue from Japan that was manufactured 02/26. Of course they delivered it with a battery that I’m sure they jumped to get it here. I have a carbon pile but my ancel told me all I need to know. It’s been on a pulse tech and now a battery minder for a full 36 hrs trying to bring it back before I give in and buy a battery and take this battery back to Nissan.
