Condensation water leak at exhaust joint
Detroit, MI
Would condensation leaking from an exhaust joint be considered a positive? Is it worth sealing up better, or just leaving alone. Maybe it could be considered good so that it is not sitting around rusting/rotting out the pipe? I know some mufflers have drain holes for this reason, but I'm not sure I've ever seen a pipe.
Example exhaust joint condensation leak
I Yellowknife in winter- engines were known to get choked out due to excessive water freezing in the exhaust. My Honda used to gurgle until I drilled small drains in both mufflers- always a small puddle wherever parked.
