Compact Binoculars
wv
My mom is asking for some compact binoculars to watch birds and goings on outside of her windows.. Im not wanting to spend alot of money on these...so any advice on something like under $50?
I am eyeing the Bushnell Powerviews right now.
If she's keeping them inside, your limited budget will go much farther buying a full-sized set.
A Bushnell 10x42 or 10x50 set can be had for $50.
The larger ones can be more steady in use especially if she is older. The decision, after cost, will turn on how long at a time your Mom uses them. Longer pushes you toward smaller. Nikon has a small, folding Trailblazer series for just over $75. Stay with 8 power as in 8x25 or 8x42 etc. big or small. If you can get larger inexpensive ones you might get a harness type strap to carry the weight for her. You're a good son for considering something like this for your Mom.
Everything said is so true.
My Dad and Grandpa (his Dad) were "optics buffs", no education beyond a combined mechanical engineering degree and Bar membership.
Grandpa made a unipod for his telescope and binoculars from a mast set into an old tobacco can filled with concrete.
He'd sit in a chair and his hands were free.
Re optics: The larger size binos let in more light and so many are affordable. I got my sister a pair from Tasco (8X45mm) years ago for $30. Big but real light.
If your Mom will only hold 'em up here and there, any cheap unit will do
If they are going to be hand held, a lower power is easier (steady) view. Larger size, larger objective typically transmit more light as mentioned. Fully/multicoated optics helps light transmission.
If you can, best to take her to a store and let her operate several herself. Fix on an object across the store as well as objects outside if they will allow (through the store glass if they will not allow). Have her adjust the the eyepiece spacing, diopter, focus, check the weight and how it feels in the hand.
Outdoor sportsman places (Cabela's, Bass Pro, Sportsman, etc) can generally have a variety. Then again, there Amazon with reviews etc.
Certain bino straps can help a steady hold.
Leica. Look know further. Don't try them or you'll throw the Bushnell's in the trash. What you don't know won't hurt you.
You're absolutely right. However, they're in the $500 - $3,000 range. He wants to spend fifty bucks.
I got a set of old soviet binoculars. Sharpest image I've seen for that money (and a whole lot more money) and useable in low light conditions. sturdy build, not too much plastic on them.
ZOMZ is the brand of mine, made for the soviet military in the 60s, I believe. I have a 7x50.
She is 73 y/o and not in the best of health. So something one handed that she can put on her lap would be used more than a two fisted world war 2 anti nazi spyglass. I see people using them at nascar races and ballgames but never paid attention to the brands.
Binoculars are measured with two numbers like this: 8x42, 10x24, 12x50, etc. The first number is the magnification, and the second is the size of the objective lens in millimeters; a bigger lens allows for more light into the optic, which results in better clarity. This is helpful for someone with older eyes.
12x50 is said "twelve by fifty".
Full size binoculars typically have a 50mm objective.
Models for things like birdwatching are usually 8x42 or 10x42.
Compact binoculars are typically 8x32 or 10x32. The smaller models are x24.
They're all much lighter than the nazi spyglass that you mentioned, but I think your best bet is to head down to your local sporting goods store and pick up a few models. Gander Mountain has a nice selection, if there's one close to you. Put your hands on some and buy one in 8 or 10 power with the biggest objective lens that you think she'll use.
Originally Posted By: krismoriah72
She is 73 y/o and not in the best of health. So something one handed that she can put on her lap.
Does she wear glasses or contacts?
Does she have astigmatism?
Cataracts?
If she wears glasses, she needs a bino with a long eye relief so she can see the full field-of-view with them on. Doff/Don with glasses gets old quick when using binos. With astigmatism, a long eye relief optical design will be mandatory.
She needs a model that is light-weight, low power, will close focus and with a wide-field optical design, with an exit pupil that's not too large or too small. Maybe 4-5mm. Anything larger will be too heavy to one-hand and keep steady, especially for a 73 YOW.
When shopping, turn a potential buy around and point it up at a bright overhead light some distance away, so you're looking through them backwards. What you're looking for is a smooth, round circle. If instead you see a hexagon,count that as a mark against it.
Hold it at your stomach and reflect an overhead light off the objective end and note the color and quantity of reflections. Any white reflections indicate not all glass surfaces have anti-reflection coatings.
Higher Q binos will have prisms made of BAK4 glass. It's a higher grade than common BK7 glass. However with all of the chinese imports, the prisms may not be the higher Q glass even if it says so due to fraud.
The challenge will be finding a bino that meets all of these criteria within your price range.
