Atmospheric pressure has absolutely nothing to do with it. Nada, zero, zilch, zippo. You can if you desire have a closed loop system where there is simply no air anywhere in the system (not in your engine obviously). The pump pumps the pumps the oil and there is no atmosphere.quote:
Originally posted by ebaker:
Re #1, the positive displacement oil pump must suck the oil out of the pan. The oil must flow thru the pickup (inlet) screen and tube. Assuming the pump can pull a perfect vacuum, the flow INTO the pump is pushed by atmospheric pressure. This limits the flow. An oil pump can not pump more flow than what comes through the inlet. Atmospheric pressure will push more thin oil through the inlet tube/screen restriction.
My water pump for example is 200' down in the ground and pumps the water 200 feet vertically to the house. No atmospheric pressure anywhere.
If a pump is designed to grab a "bucket" of oil and shove it in a pipe every time the impeller turns, then that is what it will do, barring it grabbing air instead. The impeller may slow down so that it shoves fewer "buckets" / unit of time, but each time it turns, a bucket enters the pipe. IF you can maintain the rpm of the pump, then it will pump the same volume of liquid regardless of viscosity.
That is what the gentleman is saying.
