First I will relate my experiences when I started fooling around with some additives a few years ago.
I was driving an '83 280ZX that was tuned to specs and totally stock. In fact I owned 2 of these cars in succession...both '83s 2.8 L straight 6 EFI with manual trans. Both got around 24 mpg mixed.
At some point I started using moly in both the engine and the trans and diff. I changed the oil in the engine every 3K miles at this time...at each oil change I would add some kind of additive...I think I was rotating between moly....teflon...and militec. Also changed the diff/trans oils out and probably had used militec, teflon, and moly...but not at the same time.
The mpg result was around an 8 to 10% gain in mileage...simply from using additives. I haven't been able to duplicate this since though (at least not validate it).
I do use additives in engine/trans/diff with all the vehicles I drive now...but I think it was some combination of additives that caused this obvious mpg gain.
I suspect it might be the militec combined with particulate moly...where the militec treatment is supposed to last for a good while...and the moly needs to be re-added at each oil change.
Also the teflon might have played a part.
My basic guess is that the good result was from a combination of a solid lubricant such as moly (this was particulate moly) and an additive that is supposed to modify the metal surface itself (militec).
There is an additive called TufOil that is supposed to combine several additives....but it is fairly expensive.
http://www.tufoil.net/?gclid=CJedt5qL144CFRAZZwod0Cu_Ww
I'm thinking that a cleaning and additive regimen might work:
Something like this...
* clean engine with water and then add Seafoam or similar thru intake to clean rings and combustion chamber
* do a Zmax treatment thru one oil change
* add militec thru another
* then use a moly treatment each oil change after
* maybe use some teflon now and then
For manual trans/diffs use militec ....then moly or boric acid?
For an auto trans use Mobil 1 synthetic ATF and Lubegard additive?
I like some intelligent discussion on the possibility of combining additives for mpg gains. I know it works. Just wondering how to repeat it.
