Just picked up a used Powermate Generator, model PM0647000. I haven't been able to find much info on it. I had a couple questions on the operation of it. The previous owner, for reasons unknown, clipped the wires for the auto idle solenoid/actuator "A". I can get the unit to start and Idle with choke in and rod "B" held to the left. If I release the rod the engine wants to die unless I pull the choke out and then it runs at full speed. I assume this is normal operation for a unit without the auto-idle function and a simple tortoise/hare lever? That being said
1- Is this normal operation for a non-auto idle unit?
2- Is it safe to operate the unit in this manner?
3- Can I safely convert this unit to propane with it operating in this manner?
The intended use of this unit is for emergency power over the winter for any power outages. Thanks in advance
