Cold Starts E90 328 BMW
Ndx
IL
Hi Guys,
I'm experiencing some strange cold starts.
It cranks 2 times longer then warm ..
After starts it a bit rough..
I cleaned MAF, Add injector cleaner to gas, Swapped Battery I'm using only premium gas.
Any ideas where should I look ?
I'm thinking at this point leaking injector or fuel pump.
Thank You.
A leaking injector would make hot starts worse, not cold starts.
You are almost certainly experiencing a LACK of fuel when cold.
Why? All sorts of reasons. Dirty MAF, bad TPS, fuel filter, dirty injectors, vacuum leak.
mechtech2
Thank you thats what I needed some expertise ...
Maf - Cleaned
TPS - that should throw codes ? ( This would appear on only cold start ? )
Vacuum Leak .. is spraying carb stuff okay on modern engine ? Or should I run smoke test ?
Thank You
Ndx
No CEL?
I would suspect Vacuum leak, MAF, coolant temp sensor.
I think you mentioned this was a salvage vehicle? accident? could there be wire damage, or physical damage to a sensor?
Could be evap system leak, but I would expect a CEL.
Hey,
I have another one .. starts fine ...
No there was no front end damage so its unlikely ...
Hey,
Small update today was really dump+rain car started I think normal still a bit longer start then warm but it was smoother for sure ...
Maybe Coils are bad ? should I lube them inside with some grease ?
Computer never recorded misfire but that could be the case ?
I know this is a bad idea, and never recommended, but you could swap some parts between this one and the other one to isolate the problem.
