zoomie
Probably about the time you've got your coffee cup into the holder, your coat arranged, and your seatbelt buckled, your engine is ready for slow driving. Driving it easy is the best way to warm it, and the lubrication of an easy running engine is no problem.
There are significant advantages to engine heaters--
--lower fuel consumption, 'cuz the cold engine is programmed to run rich
--cleaner air for the reason above
--earlier occupant comfort
--less cold-start engine wear because the engine's internal dimensions are closer to the warm engine running dimensions.
"Wind Chill" is a term used to denote the cooling effect of wind on flesh. Air flow does help cool machinery by removing any boundary layer of still air, but let's keep the terms separate and clear.
