Quote:
Well, I gave it a try... drained the oil cold. I'll let you draw your own conclusions. I always use a litre of Mobil 1 0W20 and 2.5 litres of Mobil 5000 5W20. I have a Honda Civic Hybrid. The drain usually takes about 45 minutes. It was still slowly dripping out two hours after I started. I always pour a couple of tablespoons of fresh oil at the end to see if there is any deposits/gunk in the pan. The extra oil has always come out just as it went in - clean. This time, after two hours, I put in my normal couple of tablespoons of fresh oil and out came more black gunk,tried it again - same result. I used about half a litre before it started running out clean again.
