nope
I use the same type of cannisters for my beans...paid $15-$20 each on Amazon. They work great.I used a the least expensive Mr Coffee maker for years until it shot craps. Then I received a Kuerig single cup maker and used that until it died.
Now I have one of these. https://hamiltonbeach.com/the-scoop-single-serve-coffee-maker-47550
It makes a perfect cup of coffee in both flavor and brew time at just the right temperature. I use most of all Aldi's coffees.....
https://www.aldi.us/en/products/bev...imo-french-roast-or-house-blend-ground-coffe/
Lastly, I store them in this, which keeps the grounds fresh all the way to the end. https://www.amazon.com/Coffee-Gator...t=&hvlocphy=9051761&hvtargid=pla-823571312612
That's where I set mine ...I use an Oxo conical burr grinder and brew in a French press. I set it to grind at medium coarse (10).
Trying to get my wife off the Keurig. I don't like the spent cups. The #4 filters I use in an ancient Cusinart 12 cup drip get tossed on my compost heap.I used a the least expensive Mr Coffee maker for years until it shot craps. Then I received a Kuerig single cup maker and used that until it died.
Apart from the waste, another reason that I dislike Keurig is that the capsules are plastic and they seem to impart a slightly off taste to the coffee.Trying to get my wife off the Keurig. I don't like the spent cups. The #4 filters I use in an ancient Cusinart 12 cup drip get tossed on my compost heap.
Andy, I here you. I am not an alarmist, but I cannot help to think that heated plastic touching our food is a good thing.Trying to get my wife off the Keurig. I don't like the spent cups. The #4 filters I use in an ancient Cusinart 12 cup drip get tossed on my compost heap.
Unbox that bad boy. We all wanna see
I tried stirring the grounds during brewing. I've also tried turning the Moccamaster off for 30 seconds to interrupt the brewing...so-called pre-infusion or "blooming". My previous Motif Essentials coffee maker had that as a feature. I'm not convinced it has any effect on the taste of the coffee. I belive it's coffee voodoo.Ar home I have the smaller size Moccamaster brewer with the thermal carafe and a Capresso Infinity conical burr grinder. In my RV I use a Zojirushi water boiler, a blade grinder and a Clever Coffee Dripper. If I had to choose which makes the best coffee I would choose the CCD which is saying something because the Moccamaster makes excellent coffee. I stir the grounds in each device during the brewing/steeping process. Beans get stored in the freezer or in an Airscape canister.
Bunnzilla time
For me the blooming phase is different than stiring. Blooming in my experience has been when really fresh grinds off gas and expand when first hit by water. Letting it bloom gives the grinds a chance to settle down before you add more water, thereby avoiding a huge mess.I tried stirring the grounds during brewing. I've also tried turning the Moccamaster off for 30 seconds to interrupt the brewing...so-called pre-infusion or "blooming". My previous Motif Essentials coffee maker had that as a feature. I'm not convinced it has any effect on the taste of the coffee. I belive it's coffee voodoo.
