Originally Posted by Astro14
Originally Posted by demarpaint
I have two from them, a Winchester vintage 1943 and a SA from 1942. Both are in very good condition. I have to look into getting the Winchester to operate correctly though. After it fires the first round the second round ends up jammed with the bullet and part of the case jammed up over the breech. IIRC they call it "stovepipes the round."
Sounds like a bad Mag. Have you tried others? Also, is it an original mag as opposed to aftermarket? Origs all have a letter or symbol stamped on flat side. Print the letter/s or email to me and I'll tell you if its a GI mag.
Thanks for the info. I tried other en bloc clips, [all of them are GI clips] ball ammo, handloads, and store bought ammo. None of the mentioned helped. I think it is a timing issue. It has been on the back burner for several years now. Threads like these remind me of the problem.
Too bad you don't live closer...
Stove pipes are very rare in Garands.
Many Garand issues can be solved with a good clean, lube and new springs. A complete spring set is $28 from places like this:
https://www.ammogarand.com/m1gaspspsetf.html The op rod spring is only $7 for new one (and it's usually at fault, since both the op-rod and the follower rely on the op-rod spring for proper function).
While you've got it apart for the new springs, perform a "tilt test". With the stock removed, take out the op-rod spring and re-assemble the op rod to the action, with the bolt in place. It should slide freely back and forth. Tilt the rifle to 45 degrees inclination, barrel up and the op rod and bolt should slide back. Tilt it to 45 degrees with the receiver up, and the op rod and bolt should close.
If they don't, the op rod is likely dragging on the handguard or barrel and that clearance will need to be adjusted (note that an op rod has two slight curves/bends in it when properly shaped. Don't ever try to straighten them.)
If your rifle were short-stroking, I would say that you've got a gas leak, or lack of lubrication. But the bolt is going far enough back to pick up the next round, so the action is cycling far enough that I think your gas system is OK.
The only timing that you can really adjust in the Garand is the bolt release upon clip insertion. That's checked with a timing block that simulates clip loading. The nose of the bullet guide gets worn, and the op rod catch won't release the op rod when the clip is fully inserted, requiring the shooter to "bump" the op rod forward. Many shooters think that's normal. It's not. It's common because of the wear. Peening the nose of the bullet guide back to roughly 0.185" height, or just replacing the bullet guide, restores proper bolt closing on clip insertion.
Winchester receivers are more roughly machined (larger tool marks, rougher finish) than Springfield or H&R receivers. While I love the Winchester rifles for their history, they can be more problematic than Springfield or H&R. My IHC Garand has a nicely finished receiver as well.
Because of that, I would go for a good clean and lube first. I am fond of Mobil 1 grease. The red color allows you to see what's been greased properly (very thin film). Simply put, if there's a spot where the parkerizing is worn, that part should get a thin film of grease.
Here's a good guide:
http://www.garandgear.com/m1-garand-grease
Thanks for the info! I wish I lived closer. A friend of my son's offered to take it to an old timer friend of his who works on them. All he asked for was a bunch of ball ammo to use for testing and confirming the repairs. At the time I only had about 10 rounds, in fact that's all I have now. Then due to my lousy schedule at the time we never hooked up. I'll try another cleaning and lube job one of these days, if that doesn't work I'll hook up with my son's friend and make it happen. Aside from routine cleaning and lubing I don't have the comfort level to dig too deep into it yet! The other issue is I would have to take it to the range to test it, and if it doesn't work properly I'd have to bring it home and try again, a 60 mile drive each way. They're strict about repairs etc. on the range. That would mean taking it home and trying again.
You're right the Springfield is problem free, the Winchester was this way from the first day I got it from CMP. I was extremely happy with the condition and never informed them of the issue.
