Clutch pack clearance th400
Rebuilding a th 400.
Checking clearance in front and direct.
Front 1 wave plate 5 frictions and 4 .080 steelplates.
.050” clearance. Ok or should I tighten up to .040”?
Direct 5 frictions and five .090” steelplates .080” clearance.
Should I replace the bottom .090” steel with double .060” steels? Ok to run steels against steel? Ok with thinn steels?
3400 lbs chevelle street/strip bbc 600-700hp 600+ft/lbs
3500 stall. 12 bolt 3.42.
.010" per Friction is standard on performance TH400's in the Forward, Intermediate & Direct clutch packs.
You can run the Forward Clutch a little tight....., .040" is fine. Stick with .010" per on the Direct & Intermediate clutches.
Do you have access to a Lathe? You can face the piston off @.030" then run a .060" steel under the bottom .090" Steel, In theory this would tighten the pack up by .030" & put you near .050" clearance. The .060" steel will act as a shim.
*Option #2....
Run 6 .077" nominal (.080") Steels & 6 Frictions in the Direct Drum & face/machine the Piston accordingly, Some drums will accept 6 .090" Steels & 6 Frictions. Measure twice....Cut once!!!
I don't like running steels thinner than .077" against a Friction.....The Steels act as "heat sinks".
If you do not have access to a Lathe....Run a couple of .077" in place of the .090" Steels & add the .060" under the bottom steel......Or however you need to do it to get the clearance right.
Ok many thanks! Think my best option is to face the piston .030” and add a .060” steel.
*Option #2....
Or maybe even face .047 an run a .077” steel in the bottom under the .090” since .060” is harder to find in Sweden and like 40$ each.
