Closest ATF to Dexron II?
Ca
What's the closest ATF one can get to Dexron II.
Vehicle is a 1989 Dodge Colt (which is a Mitsuibishi). Factory service manual says Dexron II.
90K miles, fluid is brown and smells worn. Transmission shifts ok.
Generic "DexMer" from anywhere.
Mobil ATF from target mets some (caterpillar?) spec that is a cut & paste of DexIII.
Yeah I know you typed "II" but III is quite close. There's someone on here with some honda Dex II in old, sealed bottles.
For what it's worth, I have a friend that has a Dex II application and it shifts as smooth as butter with Advance Auto store brand Dex/Merc.
Yep any major auto parts store dex merc would do the trick. The Mobil D/M at at target is one of the best mineral based Dexron/Mercon you get if you want something nice.
I have a 95 nissan that calls for dex II. I tried maxlife and the transmission hated it. Laggy shifts and popping out of 4th gear. I assumed maxlife was too thin for it so I pumped it out and filled with Castol Import multi-vehicle atf and it shifted better than I've ever remembered. I've tried other atfs like supertech dexIII and advance auto dex/merc they worked ok.
Do yourself a favor and introduce the new fluid slowly. I would do a pan drop and filter and only replace what fluid you get out. I would not flush that trans. Once you have done the drop then do a drain fill every 5000 miles 3 more times.
Originally Posted By: friendly_jacek
Originally Posted By: Bottom_Feeder
Use MaxLife Dex/Merc and call it a day.
not in a manual tranny specifying dex.
Who said it was a manual?
What Doog said...I'd switch fluid a few times...
And not so much the fluid itself, but with the age of the car. Might shock it too much if you do a complete fluid drop. This way it won't mess with a build up there there or leak or who knows what....
Co worker just did that with a 93 Escort wagon his aunt gave him. Says the car shifts great now....
zzyzzx has it right. I have serviced a few cars requiring Dex II and put this stuff he has in the picture and it works fantastic.
Originally Posted By: zzyzzx
I use thin in my 1995 Escort, and I have over 216K miles on it's vintage 1995 automatic transmission:
Any dex/merc would work. I have had good luck with the Supertech Dex for my Malibu but will be switching over to Maxlife. I think it will make a big difference with Maxlife versus the older Dex II. I would also plan on having it flushed or drain/fill a couple times to get the fluid fresh.
that's the thing, we don't know.
It's an auto, sorry if that was unclear.
3 speed auto.
Definitely using this method. The pan even has a drain bolt, which makes matters somewhat less messy.
Not really any need to introduce it slowly if you're using a mineral based dex merc, just do one drain and fill every 1000 miles until you get 3-4 under your belt then you can extend the intervals.
