Clorox bleach shelf life... I had no idea.
I can see why they would think that it would not be in their best interest for the customer to know exactly how fresh their rapidly degrading product is.
The alternative though is customers complaining that "my Clorox doesn't work like it used to", not knowing the reason why. I've always known that bleach "evaporates" when opened but I thought it was pretty stable as long as it's kept in a closed bottle.
Great thread. I knew it aged fairly quickly. I also thought it was a gas which simply left the solution.
I've never seen Clorox in a Costco type store figuring they'd want to completely avoid having a caustic spill....especially with the requisite larger size containers.
Anybody ever do the "greasy and chunky black pan in a sealed plastic bag with Clorox overnight" trick? It's amazing.
It's the smartest thing my sister's second husband ever showed me.
Wow! Apparently bleach expires a little slower than a gallon of milk. The only alternative to this is to research the date codes and buy only that day or week when you need it.
Upon pouring the 6 year old Clorox I noticed a fluffy white substance coming out of the jug as well. It looked like small chunks of wet paper swirling about. Perhaps the chemical compounds separated.
Did not know. Wife won’t let me touch the laundry, plus I don’t think she uses bleach in the first place. No pool either.
I don't remember the last time I used bleach in the laundry .
I do wonder what laundry of ours is bleached anymore too. No tighty-whities, almost no white socks (only in winter for me), very few white towels... Only thing I can think of is my wife wears white tank-tops under her scrubs. We certainly don't buy bleach as much as we used to either.
You can use bleach in your washer's self cleaning cycle. Having disassembled older washing machines, you definitely want to clean your washer
You can use bleach as part of the cleaning cycle, but by itself, bleach isn't a cleaner (detergent). It really won't remove crud and other build-up inside the machine.
Bleach in a washer is only active for about 3 minutes. That's why the bleach dispenser energizes in the last minutes of a wash cycle.
Plus bleach kills the enzymes in todays phosphate free detergents that are enzyme based now so its introduced in the last 3-4 minutes of the cycle.
Learned that in laundry school when they phased out phosphates.
You can use bleach in your washer's self cleaning cycle. Having disassembled older washing machines, you definitely want to clean your washer :sick:
With low water use machines scum builds up above the normal operating water level from splash. The clean cycle spins the basket faster to swirl water around the outer tub to break up the build up hence no clothes when using the cycle. Use a dedicated cleaner for best results. Bleach just makes it smell ''bleachy'' so it smells clean.
In laundry, bleach has two functions, the first being to help whiten clothing (remove stains, etc) and the second is to sanitize. And yes, it kills the cleaning agent (enzymes) in many modern detergents so that's why it's injected last. Same principle applies in dishwashers except they use extremely hot water or steam to 'sanitize' instead of bleach.
But people associate bleach smell with "clean". 😁
Interesting. Is there something else that is more effective?
The instructions for my Whirlpool made washer says to use affresh washer clear tablets or 1 cup (236 ml) of bleach with the clean washer cycle:
The main ingredient in the affresh tablets is sodium percarbonate (oxygen bleach)
Clean cycle is hot water, but most hot water heaters are set to 120f, sometimes its not hot enough to break down the soap scum build up hence running the clean cycle more frequently. Constant cold water washing increases the build up faster also, especially with folks on their own well water that's usually 45f year around.
Cleaners like Affresh are less corrosive on the pot metal basket support used in front loaders than chorine bleach.
It also includes sodium carbonate - soda ash - a very old, but very good cleaning agent. Those tablets are probably "time release" and the water dissolves the different components at different times. I'm fairly confident that the sodium percarbonate is the final step.
When they say you can also clean it with just bleach, well, the fact is no one will know if it's really clean....but it will smell clean !
Working night stock at a grocery store putting myself through college taught me this about bleach. We had to rotate it religiously. Hydrogen peroxide is the same. Once it’s opened it just lasts weeks. So go to the medicine cabinet and pitch it lol.
I have a Electrolux front loader new washer dryer set and it gives reminders of when to run the self cleaning cycle. When it comes to washing clothes the only water temps to use are cold and hot. Warm cycle does nothing, just wastes energy.
I think they have a vent too.
They're more like check valves, though not 100%, I'm sure. They release pressure from inside but shouldn't allow (much) outside air in. That said, even threads aren't 100% air or water-tight.
