"As far as I can tell from looking at various SuperTech and Bosch Premium filters, all E-cores are of part numbers which previously were supplies as the short lived clicker design."
The 3980 (Chevy 4.3 motor) has changed to the ecore design and it does NOT have the internal bypass.
As to how that "clicker" bypass is supposed to function..the only way I can see it working is that the oil has to come in through the central hole in the tensioner leaf spring and force the endcap to flex inward to expose access to those 6 smaller holes and then straight shot out the exit hole of the filter. Those that have tried to make that work manually obviously get that "cow at a new gate" look when they try it...no wonder it doesn't seem to be working. It possibly may depend on hot oil temp to make the metal expand sufficiently for that to happen-bad idea for a bypass that should work with cold oil.
The other suggestion about the cartridge actually pushing down on the leaf spring to activate the bypass may be a theoretical possibility,,,but I wouldn't be putting my money on that possibility at all. If that cartridge actually moved at all the oil would start short circuiting right at the inlet area instead of the far end.
Nope, I'm saying that "clicker" idea was a low percentage of success possibility right out of the box..not the first time I've seen a bad/marginal design make it from the first discussion over drinks at the bar to the drawing board to customer use....The ecore design at least looks like it can work,,,just gotta prove'em out a little longer far as I'm concerned.
