Cleaning Wheels
Quote:
DO NOT USE A MAGIC ERASER ON YOUR WHEELS!!!! It will damage the clearcoat.
True.
Originally Posted By: buster
Well, the Mother's Wheel and Tire cleaner worked well. Did a decent job. Thanks for all the suggestions.
That stuff is mediocre, try the Eagle One stuff next time, its a big upgrade.
Try One of the following
Seafoam and a shop rag
Eagle One A-Z Wheel Cleener
Diluted 1:4 Meguiar's All Purpose Cleaner (water based)
Clay Bar
You'll want to say 4:1, especially if you word it like that. That reads 1 part water to 4 parts APC, which is backwards.
I used one of the stronger wheel cleaners and Mr. clean eraser on the INSIDE of my wheels to clean off 15 years of brake dust. I would spray on cleaner, set for 1-2 minutes, scrub, rinse and repeat untill clean.
Do not let these cleaners set on the front surface too long as it might damage the front finish as many of these cleaners use acid to help clean.
No problems now that I have ceramic low dust pads.
A lot of people have used magic erasers on alloy wheels with great success. They're just melamine foam, which admittedly is a very mild abrasive. But your other choices aren't much better, those special wheel cleaners aren't exactly mild either.
*if you're worried, then just try a small inconspicuous area first as you would with any new product.
Originally Posted By: Old Mustang Guy
I have found that keeping the wheels waxed makes them much easier to clean. Then you shouldn't have to use anything stronger than your car wash soap.
+1 I've always waxed my wheels and had good success with just washing them. Nothing really "sticks" to them, such as brake dust, dirt, etc.
Worked on some insanely crudded wheels today of a Windstar and gave AZ wheel cleaner a shot. Holy cow. That stuff eats through grime unlike anything I've used. +1 from me.
I use Bleche-White but really - it seems to be a bit harsh. I always feel like I need to wax them afterwards.
That's the key - keep them waxed a few times a year and the gunk will come off with regular soap and water.
