Cleaning the engine bay very regularly is the best approach
Because if you don't do it very regularly, then it gets to a point that it will be hard work to clean it then. I use a small portable blower to first blow all the dust off, then use a towel and detailing spray.
Please share your experience of keeping your engine bay clean.
Thank you
I use Target bags to cover my alternator and the under hood fuse box, and I wash it. I like to use the foam cannon with the pressure washer, then a couple of buckets of scalding hot soapy water poured over everything, Wash the underneath and non-sensitive parts with the pressure washer, then rinse with a garden hose, dry with the leaf blower and the air compressor. No problems in 40 years, except with my '93 Dodge Shadow. There's a couple of relays that control the transmission that were supposed to be mounted vertically to the inner fender, but they were laying horizontally on the frame rail and got water in them. Had they been mounted correctly, my engine washing record would have gone untarnished. 😅
After every oil change I hit the engine bay with patio furniture cleaner from a spray bottle. Cool engine, let it soak a minute or two then rinse it. I hit everything but try not to directly spray the fuse box too much or with high pressure. I spray the condenser and radiator as well then low pressure water rinse.
After this go for a short drive to dry everything out. I don't use any spray dressing or silicones under the hood, don't want an O2 error code.
I think either Eric the Car Guy or South Main auto showed the parasitic drain on a battery from the dirt/moisture on top of it.
I spray Simple Green a couple times per year all over it and then rinse with regular hose. Doing that lets you see when you are starting to have any VCG issues or others leaks. Common sense applies not to spray hard directly at connectors or alternator. Big water might get wiped down afterward with an older beat up microfiber.
about 100k on my Accord.
220k on my old Sonata.
