Cleaning parts without parts washer
CA
Let’s say you are working on this at a location without a parts washer. What is the most efficient way to clean these parts?
(Some of you may recognize that these are Honda J-series parts - oil pan and oil pump.)
A friend of mine is a mechanic and he had a bunch of nasty parts from an old car, timing cover, intake manifold etc. and he had a gas tank he had just pulled from another car with rancid old gas. He soaked everything in it and they came out like new. I wonder if new gas would work too.
Steel parts? Oven cleaner and a hose, blow off with air gun after rinsing and maybe spray with a light coat of something to keep it from flash rusting.
Aluminum parts? Super clean/Purple power/simple green/some other fairly strong degreaser, let it soak for a while, and a hose. Maybe a scrub brush as necessary. Blow off with an air gun after rinsing.
Diesel will work wonders if you have a container deep/wide enough to let the parts soak for a bit.
Stuff like that I take to the self-serve car wash, soak it with degreaser and blast it off. Fast, cheap, no mess, and no nasty chemicals. If the parts are not too dirty I just use my pressure washer at home.
It would depend on how clean you want it. If it's Internal - gas or diesel. External- Purple Power and High Pressure Water
The issue with all of the suggestions is the run-off/waste water - pretty sure it is not okay to allow such a large quantity of oil/grease to go down the drain?
I have a plastic trash can. I put hot water and Dawn in it and let the parts soak in it. Dawn now has some Heavy Duty dishwashing liquid that they sell at Lowe's. I bought some of that to give a try the next time I need to soak parts.
