Cleaning oxygen sensors
just let it burn off. considering the amount of heat and pressure o2 sensors see, you should have nothing to worry about.
Let it burn off, you shouldn't have any problems.
I would be more worried if you dropped the sensor on the floor.
If you must you could spray electrical contact cleaner on them. It quickly degreases and clean than evaporates away quickly. Other than that - it's self clean itself at 600+ degrees.
