Cleaning Funnels
All kinds of different ways to clean a funnel. The fastest and most convenient way I suppose would be brake cleaner and compressed air.
That's if you have compressed air available and can afford the price of brake cleaner at over $6 a can just for cleaning funnels.
What other ways are there to clean a funnel?
  • Like
Reactions: Arc
Gasoline dampened rag. Wear protective gloves. Let rag dry after by leaving it out in the sunlight.
How do you get the rag down in the narrow area of the funnel; you stick a phillips screwdriver in there and ram it through?
A shot of brake cleaner and a wipe down with a red shop towel is how I always do it but I'm open for a better way?
With the shop towel, you're taking a chance on introducing micro particulates with a static charge to the plastic funnel.
Similar question. I actually have a couple new funnels I picked up for my Toyota ATF. Do I need to clean them before I use - one is metal with the flexi spout, the other is plastic. Not sure which will work best - first time use?
You may find some helpful hints in these previous threads touching on this topic::
